Flexiforce Sensors(A201)
Postby zhui » Wed Nov 05, 2014 12:02 pm
hello, i wan to ask is it Flexiforce Sensors(A201) can be connected with arduino uno? becoz at the tutorial there mention connect with BBFuino. I may want to connect Flexiforce Sensors(A201) and Force Sensitive Resistor 0.5 Inches together with the arduino uno board at the same time. It is possible?
zhui
Re: Flexiforce Sensors(A201)
Postby Idris » Wed Nov 05, 2014 12:18 pm
Yes, you can. :)
Postby ober » Wed Nov 05, 2014 3:12 pm
BBFuino is similar to Arduino UNO, In different form factor only. Just follow the pin connection from the diagram. I am sure the BBFuino have label of the pin, follow that pins connection/interface with the sensor. Load the example sketch and you should be able to get it.
