Suitable DC motor for Balancing Robot
Postby aswad » Fri May 29, 2015 4:16 am
anyone can help in selecting SPG30E dc motor?
which must consider high torque or high rpm? (in balancing robot context)
confused to make decision.
aswad
Re: Suitable DC motor for Balancing Robot
Postby ober » Fri May 29, 2015 5:43 pm
High speed and moderate torque is good as we want to make it stable, not to stand the robot up from laying position. Yet, it still depends on other factors, such as the weight of the robot, center of gravity, wheel size, etc.
Suggestion: SPG50-20K
Postby aswad » Fri May 29, 2015 6:18 pm
ober WROTE:High speed and moderate torque is good as we want to make it stable, not to stand the robot up from laying position. Yet, it still depends on other factors, such as the weight of the robot, center of gravity, wheel size, etc.
but it not come with encoder, is it SPG30E-30K ok?
aswad
Postby ober » Fri May 29, 2015 11:34 pm
Balancing does not necessary need encoder, but of course encoder will help a lot. Sure, you can try the SPG30E.
Postby aswad » Mon Jun 01, 2015 12:55 pm
one thing more, is it possible to feed kalman filter into PIC16?
aswad
Postby ober » Mon Jun 01, 2015 11:03 pm
we have port the Kalman filter into PIC18F before, never try PIC16F before, but I believe it can be done.
Postby aswad » Wed Jun 10, 2015 11:27 pm
i decide to use SPG30E-30K
but the item are out of stock.
So when the item will re stock up?
aswad
Postby ober » Fri Jun 12, 2015 12:49 pm
Just checked with our purchaser, estimated next week it will be re-stock.
Postby aswad » Mon Sep 21, 2015 4:15 pm
is it have different if using 3x 3.7V 1100mAh Li-Ion Battery and LiPo Rechargeable Battery 11.1V 2200mAH
in term of speed or torque?
seems 20k 185rpm not enough in balancing if using 3x 3.7V 1100mAh Li-Ion Battery
aswad
Postby aswad » Mon Sep 21, 2015 4:24 pm
really need help, now program with propotional gain, seems motor not enough,
aswad
Return to DC Motor
