BlueBee 4.0 master and slave
Postby hiphop9686 » Wed Mar 30, 2016 4:41 pm
Hi, I would like to ask , what if there are 2 Bluebee 4.0 slave modules in nearby, and one master Bluebee 4.0 module
Can the master connect to both slave module? or only 1 slave at once?
hiphop9686
Re: BlueBee 4.0 master and slave
Postby Nurul.Syuhada » Wed Mar 30, 2016 5:18 pm
Hi, it is only one slave at once. Thanks. ;)
Nurul.Syuhada
Postby hiphop9686 » Thu Apr 07, 2016 1:58 pm
I want to ask, how the master recognize the slave for the first time? i mean before master connect to one slave?
After connect, then the master only looking for the slave it connected previously right? how it recognize the slave if 2 slave are on-ing at the same time? MAC address?
If so, can i check the MAC the address that master recognize to?
hiphop9686
Postby bengchet » Mon Apr 11, 2016 11:17 am
Check this tutorial, at section Configure BlueBee 4.0 as master **Very Important. That will explain how master recognises the connected slave.
To get the address of slave, you can enter AT command which gives last connected device address. AT command can be found in AT command list.
