memory problem in LSA08
Postby abhinab » Fri Jun 24, 2016 6:47 pm
I'am using LSA08 in UART mode 2 with arduino mega 2560. It works fine for one time I calibrate it. After one or more time of switching the power supply(12V to Vin), the calibrated data is lost, and works if I re-calibrate it. I get zero every time, in every position when I get that problem.
Also, first two-three data obtained from UART line is incorrect. and next data obtained will be correct. This happens every time when I switch the supply. But, above first problem occurs at random time.
* lineSensor.cpp
* Created: 5/9/2016 6:18:36 PM
* Author: Abhinab
#include "lineSensor.h"
#include "uart.h"
#include "ADC.h"
void setContrast(char value)
char address = 0x01;
char command = 'S';
char data = value;
char checksum = address + command + data;
UART2Transmit(address);
UART2Transmit(command);
UART2Transmit(data);
UART2Transmit(checksum);
void clearJunction()
char command = 'X';
char data = 0x00;
uint8_t getJunction()
if(bit_is_set(PINF,1))
return 1;
else
return 0;
uint8_t getLineState(void)
REQ_DATA;
//wait for data to be received
while(!((UCSR2A)&(1<<RXC2)));
STOP_DATA;
//return received data
return UDR2;
//uint16_t presentData=readADC(1);
//if(presentData>990)
//return 255;
//return ((float)presentData/960)*70;
uint8_t getJunctionSensor()
uint16_t presentData1=readADC(14);
uint16_t presentData2=readADC(15);
if((presentData1<400)||(presentData2<500))
return 1;
else
return 0;
void calibrateSensor()
STOP_DATA;
char command = 'C';
char data = 0x00;
void lcdBackLight(char intensity)
STOP_DATA;
char command = 'B';
char data = intensity;
void setJunctionWidth(char jWidth)
char command = 'J';
char data = jWidth;
void setOutputMode(char mode)
char command = 'D';
char data = mode;
void setBaudRate(char baud)
char command = 'R';
char data = baud;
abhinab
Re: memory problem in LSA08
Postby Idris » Thu Jun 30, 2016 9:16 am
Hi abhinab,
Sorry for your inconvenience.
What do you mean by switching the power supply from 12V to Vin? What is the purpose doing that?
Postby abhinab » Fri Jul 01, 2016 7:35 pm
Idris WROTE:Hi abhinab,
By that, I mean to switch(ON and OFF) the 12V signal connected to Vin pin of LSA08, to power the device.
abhinab
