Cytron Shield-ESP-WiFi Rev 2.0 with Blynk
Postby fariqatrash » Wed May 17, 2017 8:11 am
Hi there.
can somebody help me on how can I connect to the Blynk with this Cytron Shield.
I always got error command comflicting with each other.
fariqatrash
Re: Cytron Shield-ESP-WiFi Rev 2.0 with Blynk
Postby bengchet » Wed May 17, 2017 11:32 am
Please refer to this post. Thanks.
Postby Syaabani » Thu May 25, 2017 2:03 pm
i already use the sketch from post but my serial monitor show this,
Syaabani
Postby Idris » Fri May 26, 2017 2:30 pm
Hi Syaabani,
If not mistaken, software serial is quite hard to handle high speed baudrate (i.e 115200). You can try to lower down the baudrate to 9600bps.
Postby Syaabani » Fri May 26, 2017 4:34 pm
I ALREADY CONNECT WITH BLYNK BUT HAVE ERRO THERE. CAN U HELP ME SIR?
Syaabani
Postby Idris » Fri May 26, 2017 5:40 pm
Hi Syaabani,
It is connected to WiFi network, but not connected to Blynk server. Either the internet is slow, or Blynk server got problem. Try to restart you board (power off and on again).
Postby bengchet » Sat May 27, 2017 7:31 am
You can add few lines as the code shown below. This is to reset the ESP8266 module before starting the program to solve "Failed to enable MUX" issue.
If it shows "Failed to disable echo" issue, it is pin selection problem for UART, so you need to double check either the mini jumpers or at the coding.
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "your auth token";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "your ssid";
char pass[] = "your pass";
// Hardware Serial on Mega, Leonardo, Micro...
//#define EspSerial Serial1
// Software Serial on Uno, Nano...
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set console baud rate
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(ESP8266_BAUD);
  delay(10);
  EspSerial.println("AT+RST"); <-- add these 4 lines here
  delay(1000);
  while(EspSerial.available())
    EspSerial.read();
  Blynk.begin(auth, wifi, ssid, pass);
  Blynk.run();
Attached is also screenshot of my test, I used Uno, but it should work for Mega as well.
Re: Cytron Shield-ESP-WiFi Rev 2.0 with Blynk (SOLVED)
Postby Syaabani » Sat May 27, 2017 9:06 pm
thank you for helping me. <3 CYTRON
Syaabani
Postby Idris » Thu Jun 01, 2017 10:49 am
Hi Syaabani,
Glad to hear that. :)
Postby muizz21 » Wed Feb 28, 2018 2:54 pm
how to connect to wifi (blynk) with use the battery without use serial monitor?
muizz21
