Infra-Red distance measures: Send distance value in centimeters to serial
Connection the sensor to the Arduino:
sensor - arduino
VCC - 5V
Gnd - GND
OUT - A0
Briefing:
This program has the sole purpose of measuring distances with the Infra-Red sensor.
It uses a previous calculated regression to convert analogRead values into distance values.
const int irsensorpin = A0;
void setup() {
void loop(){
// Reads the InfraRed sensor analog values and convert into distance.
int sensorValue = analogRead(irsensorpin);
double IRdistance = 187754 * pow(sensorValue, -1.51);
Serial.println(IRdistance);
// A delay is added for a stable and precise input
delay(100);
