Data stream to favoriot using ESP 8266 rev 2.0
Postby dimasze » Tue Oct 24, 2017 9:45 pm
I have arduino uno board combine with ESP wifi shield rev 2.0
I have a problem to do data stream from the arduino sensor to Favoriot.
I try to use the code from favoriot tutorial: https://platform.favoriot.com/tutorial/?java#arduino
However, I realize that the code for WiFi is using common Wifi library which is not working with the ESP.
Then, I try to learn from example HTTPS client. However, I can only connect to api.github.com server.
Anybody can help? This is the example code of HTTPS client
* HTTP over TLS (HTTPS) example sketch
* This example demonstrates how to use
* secure_connect function to access HTTPS API.
* We fetch and display the status of
* esp8266/Arduino project continuous integration
* build.
* Created by Ivan Grokhotkov, 2015.
* This example is in public domain.
* Modified by Ng Beng Chet, 2016
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <SoftwareSerial.h>
const char* ssid = "~~~~~";
const char* pass = "~~~~~~~";
const char* host = "api.favoriot.com";
const int httpsPort = 231;
void setup() {
while (!Serial) {
if(!wifi.begin(2, 3))
Serial.print(F("Connected to: "));Serial.println(wifi.SSID());
ESP8266Client client;
Serial.println(host);
if (!client.secure_connect(host, httpsPort))
client.stop();
return;
String url = "/repos/esp8266/Arduino/commits/master/status";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
//set 5 seconds timeout for response from server
int i=5000;
delay(1);
if(i==1) {
Serial.println(F("Timeout"));
client.stop();
return;
if(client.available())
if (client.find("\r\n\r\n"))
Serial.println(F("headers received"));
String line = client.readStringUntil('\n');
if (line.startsWith("{\"state\":\"success\""))
Serial.println(F("esp8266/Arduino CI successfull!"));
else
Serial.println(F("esp8266/Arduino CI has failed"));
Serial.println(F("reply was:"));
Serial.println(F("=========="));
Serial.println(line);
Serial.println(F("closing connection"));
//flush the rest of received data
while(client.available()>0)
client.flush();
client.stop();
void loop() {
dimasze
Re: Data stream to favoriot using ESP 8266 rev 2.0
Postby bengchet » Tue Nov 07, 2017 10:34 am
For your case, you can use http only to communicate with favoriot.
const char* host = "api.favoriot.com"; <-- http setup
const int httpPort = 80;
if (!client.connect(host, httpsPort)){ <-- change secure_connect to connect
Note: Is favoriot httpsPort value 231? http or httpsPort cannot be random number, you will need to find from document. With correct ports only you can connect to server.
Postby bengchet » Thu Nov 30, 2017 1:58 pm
For those who are using Favoriot platform with Cytron WiFi Shield, here are couple of examples and references you can look at.
1) Youtube - COMPLETE Tutorial Cytron Uno with Favoriot Platform
2) Complete step by step tutorial document
