ENQUIRIES ON 12V EL INVERTER FROM CYTRON
Anything related to the ROBOT. Head to Toe Magazine.
Postby Aiman Nazri » Wed Nov 22, 2017 9:15 pm
Hello Cytron, I have bought with you the EL inverter. It is mentioned there that the frequency of the inverter is 2 Khz. However, When I try to power my EL, I measure only 800 Hz. Could you explain why?
Aiman Nazri
Re: ENQUIRIES ON 12V EL INVERTER FROM CYTRON
Postby Idris » Thu Nov 23, 2017 10:53 am
Hi Aiman Nazri,
Is it 2kHz and 800Hz will effect the EL wire performance? Could you share a few clear photos on how do you measure the frequency?
Postby Aiman Nazri » Fri Nov 24, 2017 5:27 pm
Hello,
Thank you for your response. I measure using multimeter at the EL terminal. Just to let you know, I have not try on EL wire, but I tried on my own printed EL. Thanks
Aiman Nazri
Return to ROBOT. Head to Toe Magazine
