MD30C project box
MD30C project box
Postby liteace » Fri Dec 15, 2017 2:51 am
Hi All, Im new here, I hope ive posted in the correct section,
Ive just taken delivery of my MD30C controller board and have a few questions.
I want to mount the controller in a plastic project box, on the box I would like to put the switches, pot and led's, can someone please tell me:
What value pot do I need.
What are the best LED's to use and also what way to connect them to the board,
anode cathode, positive, negative.
Will the controller work OK with a 5 volt supply and drive a 5 volt motor
And last, Ive not tested yet, I assume the controller is ground side switched
Thanks
Thanks
liteace
Re: MD30C project box
Postby ober » Sat Dec 16, 2017 6:45 am
Generally, please do check the MD30C User's Manual
In the User's Manual, we are using a 5KOhm potentiometer. So you can try with that as a start.
Well, normal 3mm or 5mm LED should be good enough. Since MD30C does not come with extra pads for external LED, you have no choice to do some soldering and hacking work. As LED comes with polarity, the easiest way is to trial and error. Putting your LED parallel with the LED and try to power up the motor to activate, if it like up, solder it!
Yup, 5V is the minimum operating voltage.
Not really understand what is ground side switched, but the grounds are commoned, power and signal grounds are same
Postby liteace » Sat Dec 16, 2017 7:30 am
Ground side switch is when there's constant power, positive +, and the negative -, is switched with the pwm controlling the motor speed
liteace
Postby liteace » Sun Jan 07, 2018 8:59 pm
ober wrote:Generally, please do check the MD30C User's Manual
Would using the 10K Ohm potentiometer give me more control ?
liteace
Postby ober » Mon Jan 08, 2018 5:31 am
liteace wrote:Would using the 10K Ohm potentiometer give me more control ?
Just update, we have retest 5K external potentiometer, and it will generate quite some heat at certain speed, so please do use 10K ohm instead.
Postby Adrare » Sat Apr 07, 2018 11:14 pm
@moderator,
Hello,
in your repply you wrote that grounds are commoned; on the board MD30C R2 I just received, it seems (according to my ohmmeter) that there is a diode between the minus power pin and the Gnd pin of the ext PWM connector (JP6 being on ext position); the cathode seems to be on the power side, anode on the PWM connector side. So my questions are:
1/ how is the Gnd interconnection made, would you have a sketch of it ?
2/ I'd like to put a 0.05R resistor in order to measure the current in the motor and prevent from overload :idea: ; this resistor should be seen by an analog port of the MCU (PIC18F), referenced to ground. Where do you suggest I should place it in the power circuit ? I'm confused with this diode between the 2 Ground... :?
Thanks a lot in advance,
Gerard
Adrare
Postby ober » Tue Apr 10, 2018 3:05 am
Adrare wrote:@moderator,
Hello,
Gerard
Hi Adrare,
The common ground is referring to:
- GND on JP3 which is the external PWM and DIR control pin.
- GND of power input (if the polarity is correct as there is polarity protection MOSFET on board)
The rest of interface including EXT POT (JP5) where an external potentiometer is connected are not common grounded.
With shunt resistor method and common ground is needed to measure from external microcontroller, you can put the resistor at the power terminal, negative terminal :
JP1 (POWER) Negative terminal ------ 0.05R resistor ------ Negative terminal of battery (Ground)
Where the microcontroller GND should be connected to Negative terminal of battery too.
