Cytron ESP8266 WiFi Shield with AndroidAP
Postby poonjon » Tue Jan 09, 2018 10:34 pm
Hi, I tried connecting my Cytron ESP8266 WiFi Shield to my phone's hotspot and it fails to connect to my destination server, however it works if I use my house wifi instead.
-It shows "failed connect to server" on the serial monitor
-I have cross checked the wifi shield's ip with the IP on my laptop, both using the same hotspot
-I tried running the example code "CytronWiFiDemo" on on my arduino using both my phone's hotspot and house wifi. House wifi works but phone hotspot does not (failed connect to server).
poonjon
Re: Cytron ESP8266 WiFi Shield with AndroidAP
Postby bengchet » Tue Jan 09, 2018 11:22 pm
May be same as this issue.
Try check if there is a line
wifi.config(ip)
in your sketch. If there is just remove it and see how it goes.
Cheers ;)
Postby poonjon » Wed Jan 10, 2018 9:41 am
Unfortunately after I remove that line I get the message "error connecting to wifi" .
im trying to get my wifi module working as a client not server
bengchet WROTE:May be same as this issue.
Here are more information regarding my setup:
-my phone hotspot is WPA2-PSK security
-setting my phone as open network does not work as well
-my wifi module SDK is version 1.5.1
-my wifi module AT is version 0.52.0.0
-my arduino is version 1.6.9
-i have tried connecting it to 2 different hotspots from 2 different phone models, both didnt work..
poonjon
Postby bengchet » Thu Jan 11, 2018 10:53 am
Can you show some screenshots on serial monitor, and also your coding? It will be easier for troubleshooting.
For your phone settings, make sure your phone hotspot SSID and password are correct (AndroidAP is too common, advise to change to a name which is more unique and easy to identify, because there might be same SSID from other android phone). Also make sure your phone hotspot set to 'allow all devices'. You can use other device or PC to connect to your phone hotspot and surf Internet.
Postby poonjon » Thu Jan 11, 2018 8:27 pm
Attached are 3 screen shots with descriptions. I'm using the cytron wifi example code, the only settings that i changed are SSID, password and IP.
arduino wifi connection works when i connect it to my home wifi
arduino wifi connection to server fails when i connect it to my mobile hotspot
this is a reference, it shows that my mobile hotspot is in fact working when my laptop is connected to it
poonjon
Postby bengchet » Fri Jan 12, 2018 10:04 am
Mind sharing your source code as well?
Postby poonjon » Fri Jan 12, 2018 10:42 am
I'm using the CytronWiFiDemo code... anyway here you go
#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
const char *ssid = "ABCD";
const char *pass = "aaaaaaaa";
IPAddress ip(192, 168, 43 ,70);
ESP8266Server server(80);
                        "Content-Type: text/html\r\n"
                        "Connection: close\r\n\r\n"
                        "<!DOCTYPE HTML>\r\n"
                        "<html>\r\n";
void setup() {
  while (!Serial) {
  if(!wifi.begin(2, 3))
    while(1);
  Serial.println(F("Setup wifi config"));
  wifi.config(ip);
    while(1);
  wifi.updateStatus();
  clientTest();
  espblink(100);
  server.begin();
void loop() {
  serverTest();
void espblink(int time)
  for(int i = 0;i<12;i++)
    delay(time);
void serverTest()
  if(client.available()>0)
      Serial.println(req);
      return;
    Serial.print(F("Request: "));
    client.flush();
    if(req.equals("/"))
      client.print(htmlHeader);
      htmlBody += ipStr;
      client.print(htmlBody);
      String htmlBody="";
      for (int a = 0; a < 6; a++)
        htmlBody += "A";
        htmlBody += String(a);
        htmlBody += ": ";
        htmlBody += "<br>\r\n";
    else if(req.equals("/gpio2"))
      htmlBody += "</html>\r\n";
    else if(req.equals("/info"))
      client.print(toSend);
      client.print("</html>\r\n");
    else
    client.stop();
void clientTest()
  ESP8266Client client;
    client.stop();
    return;
                           "Host: www.adafruit.com\r\n"
                           "Connection: close\r\n\r\n";
    client.stop();
    return;;
  int i=5000;
    delay(1);
    if(i==1) {
      Serial.println(F("Timeout"));
      return;
  while (client.available()>0)
    //Serial.print(c);
    Serial.write(client.read());
  client.stop();
poonjon
Postby bengchet » Fri Jan 12, 2018 12:22 pm
Try comment these 2 lines.
  // Serial.println(F("Setup wifi config"));
  // wifi.config(ip);
    while(1);
Postby poonjon » Fri Jan 12, 2018 10:07 pm
It works now thank you so much, may I know what is the cause of it?
poonjon
[Solved] Cytron ESP8266 WiFi Shield with AndroidAP
Postby bengchet » Tue Jan 16, 2018 11:23 am
wifi.config(ip) is for setting static IP address in your network. I am not sure if mobile network will allow you to do so.
