#include <CytronWiFiShield.h>
#include <CytronWiFiClient.h>
#include <CytronWiFiServer.h>
#include <SoftwareSerial.h>
const char *ssid = "User's iPhone";
const char *pass = "mobilehotspots";
IPAddress ip(192, 168, 1 ,242);
ESP8266Server server(80);
"Content-Type: text/html\r\n"
"Connection: close\r\n\r\n"
"<!DOCTYPE HTML>\r\n"
"<html>\r\n";
void setup() {
while (!Serial) {
if(!wifi.begin(2, 3))
while(1);
// Uncomment these 2 lines if you are using static IP Address
//Serial.println(F("Setup wifi config"));
//wifi.config(ip);
while(1);
wifi.updateStatus();
clientTest();
espblink(100);
server.begin();
void loop() {
serverTest();
void espblink(int time)
for(int i = 0;i<12;i++)
delay(time);
void serverTest()
if(client.available()>0)
Serial.println(req);
return;
Serial.print(F("Request: "));
client.flush();
if(req.equals("/"))
client.print(htmlHeader);
htmlBody += ipStr;
client.print(htmlBody);
String htmlBody="";
for (int a = 0; a < 6; a++)
htmlBody += "A";
htmlBody += String(a);
htmlBody += ": ";
htmlBody += "<br>\r\n";
else if(req.equals("/gpio2"))
htmlBody += "</html>\r\n";
else if(req.equals("/info"))
client.print(toSend);
client.print("</html>\r\n");
else
client.stop();
void clientTest()
ESP8266Client client;
client.stop();
return;
"Host: www.adafruit.com\r\n"
"Connection: close\r\n\r\n";
client.stop();
return;;
int i=5000;
delay(1);
if(i==1) {
Serial.println(F("Timeout"));
return;
while (client.available()>0)
//Serial.print(c);
Serial.write(client.read());
client.stop();
#include <TM1637Display.h>
const char* ssid = "OPPO EK";
const char* pass = "hatake95";
const char* host = "https://qcloud.unimas.my";
const int httpsPort = 3306;
#define CLK 2
#define DIO 3
const int buttonPin = 12; // the number of the pushbutton pin
int state = LOW; // variable for reading the pushbutton status
int lastState = LOW;
int count = 0;
int newcallno;//equal to state
ESP8266Server server(3306);
TM1637Display display(CLK, DIO);
void setup() {
pinMode(12, INPUT);
display.setBrightness(0x0a);
state = digitalRead(12);
if(!wifi.begin(10, 11))
while(1);
// Serial.println(F("Setup wifi config"));
// wifi.config(ip);
while(1);
Serial.println(host);
if (!client.secure_connect("https://qcloud.unimas.my", 3306))
client.stop();
return;
Serial.print(F("Succesfully connected to server"));
void sentData()
if(client.connect("https://qcloud.unimas.my", 3306))
String url = "https://qcloud.unimas.my";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("PUT"));
client.print(url);
client.print("Current Number=");
client.println(newcallno);
client.println("HTTP/1.1");//part of the GET request
client.println("Host:https://qcloud.unimas.my");
//IMPORTANT: If you are using XAMPP you will have
//to find out the IP address of your computer and put it here
//If you have a web page, enter its address(ie.Host: "www.yourwebpage.com")
client.println("Connection: close");
//part of the GET request telling the server
//that we are over transmitting the message
client.println();
client.stop();//closing connection to server
else
//if arduino can't connect to your server
Serial.println("Connection failed\n");
newcallno = state;
if (state == HIGH && lastState==LOW)
count++;
display.showNumberDec(count);
lastState = state;
newcallno=state;
delay(50);
const char* ssid = "carrotgirl";
const char* pass = "kong7000liaw";
const char* host = "qcloud.unimas.my";
const int httpsPort = 443;
#define CLK 2
#define DIO 3
int count = 0;
void setup() {
pinMode(12, INPUT);
Serial.print(F("Connected to: "));Serial.println(wifi.SSID());
if (!client.secure_connect(host, httpsPort))
client.stop();
return;
String url = "http://qcloud.unimas.my/api/v1/queues/servicing?service-counter-id=1&new-call-no=0007";
client.print(String("PUT ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
//set 5 seconds timeout for response from server
int i=5000;
delay(1);
if(i==1) {
client.stop();
return;
if(client.available())
if (client.find("\r\n\r\n"))
Serial.println(F("headers received"));
int newcallno = client.read();
if (digitalRead(12)==HIGH)
Serial.println(newcallno);
else
Serial.println(F("waiting"));
Serial.println(F("closing connection"));
//flush the rest of received data
while(client.available()>0)
client.flush();
client.stop();
newcallno = state;
count++;
lastState = state;
newcallno=state;
delay(50);
const int httpsPort = 80;
#define CLK 2
#define DIO 3
int count = 0;
pinMode(12, INPUT);
//connect to HTTP server
Serial.println("\nStarting connection to server...");
if (!client.connect("qcloud.unimas.my", 80))
Serial.println(F("Connection failed"));
return;
Serial.println(F("Connected to server!"));
count++;
Serial.println("\nOnline Counter: ");
Serial.println(count);
newcallno = state;
//Send HTTP request
client.println(String("PUT ") + "http://qcloud.unimas.my/api/v1/queues/serving?service-counter-id=1&new-call-no=" + newcallno + "HTTP/1.1\r\n" + "Host: " + host + "\r\n" +
if (client.println() == 0)
Serial.println(F("Failed to send request"));
return;
// Check HTTP status
char status[32] = {0};
client.readBytesUntil('\r', status, sizeof(status));
if (strcmp(status, "HTTP/1.1 200 OK") != 0)
Serial.print(F("Unexpected response: "));
Serial.println(status);
return;
// Skip HTTP headers
char endOfHeaders[] = "\r\n\r\n";
if (!client.find(endOfHeaders)) {
Serial.println(F("Invalid response"));
return;
//Extract valuees
Serial.println(F("Current Number: "));
//Disconnect
client.stop();
lastState = state;
newcallno=state;
delay(50);
