Understanding MDD10A
Postby ZdevZ » Tue Feb 04, 2020 4:06 am
Hi.
I just ordered a MDD10A to use with 2 775 DC Motors together with an Ardunio.
I'm going to be using a 14.4 Li-po 7500mah.
I just stumbled upon this.
"Hi, Yes. You can but you need to make sure that you have to connect a battery with same voltage in parallel with the power supply for absorbing the current generated by the motor. Thanks. :)"
So does this mean that i need 2 battery packs? Could someone please explain this?
also
What is the biggest difference between MDD10A and SHIELD-MDD10?
How is the EMF protection on these boards? Thinking for noise from the motor etc.
Thanks a lot for all the help.
ZdevZ
Re: Understanding MDD10A
Postby ober » Tue Feb 04, 2020 4:31 am
If you are using a switching power supply. If you are using battery then it is fine.
Postby ZdevZ » Tue Feb 04, 2020 5:04 am
ober WROTE:If you are using a switching power supply. If you are using battery then it is fine.
Thanks a lot for the quick answer!
Do you know if there is builtin protection against noise from the motors?
Also do you know the difference between MDD10A and SHIELD-MDD10?
ZdevZ
Postby ober » Sun Feb 09, 2020 7:49 am
If you are talking about Regenerative power from the motor, then yes. That is the reason why a battery is needed if it is powered by a switching power supply.
MDD10A and Shield-MDD10 are similar. Of course, the shield is designed to be stackable on Arduino mainboard. The rest are similar but check the Vmotor range, MDD10A has lower Vmotor.
Return to DC Motor
