Pi Pico Keyboard Emulator HELP?
Please feedback the issue encountered while using Cytron official website (http://www.cytron.com.my), Cytron Technical Forum and Cytron Tutorial site (http://tutorial.cytron.com.my) here. We greatly appreciate any comments and suggestions too.
Postby xbizob » Tue Mar 16, 2021 1:08 am
Tried to store the keys_pressed data in a file on the pico... info.txt as follows...
Keycode.A
"Hello, World!"
"https://cytro-pi-pico"
I added the following code to read the info.txt file...
keys_pressed = []
with open("/info.txt", "r") as file:
print("Reading file from PICO")
for line in file:
keys_pressed.append(line.strip())
the result is ...
['Keycode.A', '"Hello, World!"', '"https://cytron.io/p-maker-pi-pico\n"]
not like whats hard coded into the program...
[Keycode.A, "Hello, World!", "https://cytron.io/p-maker-pi-pico\n"]
tried taking out the single quotes, and other options, but cant find a way to make it work???
PLEASE HELP!!!
Thank you... Robert
xbizob
Re: Pi Pico Keyboard Emulator HELP?
Postby Idris » Tue Mar 16, 2021 9:33 pm
Hi Robert,
You can use filter() function in python to filter certain character. For example.
Reference: Python : filter() function | Tutorial & Examples
Postby xbizob » Thu Mar 18, 2021 9:38 am
#Rasberry Pi PICO ... Circuitpython
import time
import board
import digitalio
import usb_hid
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS
from adafruit_hid.keycode import Keycode
keyboard = Keyboard(usb_hid.devices)
keyboard_layout = KeyboardLayoutUS(keyboard) # We're in the US :)
# If I run the code ...............
key = Keycode.A
print(type(key))
print(key)
keyboard.press(key)
# ...........I get ... <class 'int'> and 4 ... types a lower case a
# If I store Keycode.A in line one of a file info.txt
for line in file:
key=line
print(type(key))
print(key)
keyboard.press(key)
# ...........I get ... <class 'str'> and Keycode.A and get type error
#File "/lib/adafruit_hid/keyboard.py", line 81, in press
#File "/lib/adafruit_hid/keyboard.py", line 116, in _add_keycode_to_report
#File "/lib/adafruit_hid/keycode.py", line 295, in modifier_bit
#TypeError: unsupported types for __le__: 'int', 'str'
# how do I convert this key string data intol the same imput as me defining ... key = Keycode.A
# I have tried stripping the quotes, and converting it to a int... I have tried converting it to a a list, and using split() format etc...
# please help... driving me crazy!!!!
xbizob
Postby Idris » Tue Mar 23, 2021 11:03 am
Hi xbizob,
Could you share a complete code? So that I can test it on my Pico. :)
