zhixiong86 WROTE:Thanks, it working now!
Now I only manage to get it running after I upload the code from the Arduino IDE, how to make it work without reuploading?
Maybe can check my postings...
https://m.facebook.com/story.php?story_ ... =554017662You do not need to "Check/Compile" and "Upload" the code again... you only do it once and unplug the USB cable from the PC and plug it back to regular DC 5V adaptor and it will run but it self from the ESP32 programmed chip... I hope that tips helps....
*** Wait! the FTDI driver is not recognized by Windows Device Manager... FT231X USB UART driver is not installed yet!
https://ftdichip.com/drivers/vcp-drivers/ [Select Windows Drivers!]
What to do if a non listed device in the Board Manager Library... add aditional board manager url link at ... Click 'File - Preferences', click the link below, copy the 'Stable release link' and paste it in 'Additional Boards Manager URLs'
- CODE: SELECT_ALL_CODE
https://github.com/espressif/arduino-esp32/blob/master/docs/arduino-ide/boards_manager.md
Then click 'Tools - Board - Board Manager...' Wait for a while for 'Downloading platform index'. Scroll down, install "esp32".
*** Important: Please download and use custom NTPClient v.3.1.0 Library Manager created by Idris @ Cytron.io only, else you will get error... "No Clock Time display on the Dot Matrix Display".
https://github.com/taranais/NTPClient/a ... master.zip Rodney @
http://rodyeo.dyndns.org
