PIC + LCD 2x16..
PIC + LCD 2x16..
Postby syntium87 » Wed May 18, 2011 12:14 pm
i've started to learn about the pic which being interfaced with LCD dsply..]
i've follow all steps to solder n check every pin of the LCD..n then learn the program n even try the simplest program for the LCD..using mplab anything that i copy from the PR3 source code n several others program from other website..compile n everything is succesful..
but then..when after put the LCD together with the PIC and its interface crct...turn ON n the LED just blinking..power on and off..n I can only see not very clear black bar on the 2nd line..the 1st line shows nothing except the LCD disply blink over n over again..
help me on this plz..how to solve it..?
syntium87
Re: PIC + LCD 2x16..
Postby Brian Griffin » Wed May 18, 2011 12:42 pm
syntium87 WROTE:i've started to learn about the pic which being interfaced with LCD dsply..]
Do you have a picture of the LCD and the circuit diagram?
Postby syntium87 » Wed May 18, 2011 1:00 pm
my crct? i build the same as in shahrulnizam.com..and the code i tried before is the same thing too...credit to mr shahrul..
is it becoz of intermittent prob?or maybe somethng else???
how to solve it??
syntium87
Postby Brian Griffin » Wed May 18, 2011 1:10 pm
syntium87 WROTE:my crct? i build the same as in shahrulnizam.com..and the code i tried before is the same thing too...credit to mr shahrul..
how to solve it??
Have you checked the connections between the microcontroller and the LCD? On times it may be a loose connection.
Postby syntium87 » Wed May 18, 2011 2:05 pm
yeah...done checking..nothing suspicious...hmmm...wut should i do? :?
syntium87
Postby Brian Griffin » Wed May 18, 2011 2:13 pm
syntium87 WROTE:yeah...done checking..nothing suspicious...hmmm...wut should i do? :?
Do you have a link to his project, and did you connect your circuit to a battery? Operating the circuit with HD44780 LCDs with low battery could cause the display to be absent or garbled.
Postby syntium87 » Wed May 18, 2011 2:22 pm
this is the link --> http://shahrulnizam.com/pic-lesson-lcd-hd44780/
and i already check the battery supply..the voltage is fine and the current also..
hmmmmmm...... :| :? :roll:
syntium87
Postby Brian Griffin » Wed May 18, 2011 2:28 pm
syntium87 WROTE:this is the link --> http://shahrulnizam.com/pic-lesson-lcd-hd44780/
Plug it on an AC Adapter, like 6V ones. Make sure you have the 7805 voltage regulator before connecting it to the AC adapter.
By the way, you bought the LCD from Cytron too? On some other brands I had to add some more delays in the initializing section.
Postby Brian Griffin » Wed May 18, 2011 2:35 pm
Sorry... multiple post. Ignore this post.
Postby syntium87 » Wed May 18, 2011 2:45 pm
yeah..i bought the LCD from cytron...about the adapter...i used as u said..plus the voltage on 7805 of the cct that i used also shown 5.00V sharply...hmmm
hmmm... confused.. :? what to do...
syntium87
