Operating system of UIC00B
Postby vick5821 » Fri Feb 03, 2012 6:12 pm
Hey guys, recently I am not sure I press wrong what in the pickit2 software and now causing me to have a blink in the busy indicator light(RED light) when I plug in the UCI00B into my ladtop..and when I check for communication, it stated there pickit2 do not have operating system, go to tool and download the OS..so how can I donwload ?
Thank you!
vick5821
Re: Operating system of UCI00B
Postby kl84 » Fri Feb 03, 2012 6:40 pm
Run PICkit 2 Programmer software - connect UIC00B to your computer - goto Tools - click Download PICkit 2 Operating System.
kl84
Postby vick5821 » Fri Feb 03, 2012 8:12 pm
kl84 WROTE:Run PICkit 2 Programmer software - connect UIC00B to your computer - goto Tools - click Download PICkit 2 Operating System.
But then it pop up to my files/documents ask me to choose the OS..but I do not have..so how ?
vick5821
Postby ABSF » Fri Feb 03, 2012 10:39 pm
The OS file should be in your c:\Program Files\microchip\PK2 directory if you installed it normally.
The file name is "PK2V023200.hex".
If it is not there you can download from microchip website here:
http://www.microchip.com/stellent/idcpl ... ts=pickit2
Filename is Pickit 2 firmware V2.32
Postby vick5821 » Fri Feb 03, 2012 11:12 pm
ABSF WROTE:The OS file should be in your c:\Program Files\microchip\PK2 directory if you installed it normally.
If I download from cytron website then made it be .hex file then put inside also can right ?
vick5821
Re: Operating system of UIC00B
Postby robosang » Sat Feb 04, 2012 9:01 pm
Why need to download from Cytron website? The file pointed by Allen is under PICkit 2 programmer folder, you surely will have it on your computer, else you will not be able to download the OS 8-)
Postby vick5821 » Sun Feb 05, 2012 9:03 pm
robosang WROTE:Why need to download from Cytron website? The file pointed by Allen is under PICkit 2 programmer folder, you surely will have it on your computer, else you will not be able to download the OS 8-)
I do not know last time..but then I downloaded the OS from cytron then change it to .hex file then put into my UIC00B :)
Ok also right ?
vick5821
Postby ABSF » Mon Feb 06, 2012 10:15 am
Didnt check the OS file in Cytron. But if it works then it's OK, if it doesnt work, it wont kill your PIC anyway. 8-)
Postby ober » Mon Feb 20, 2012 12:47 pm
I just upload a tutorial on how to update the UIC00B Operating System under Cytron tutorial page, click here to see.
Postby Farid89ism » Sat Mar 03, 2012 8:39 pm
Hi..i have program my coding into my pic(pic16f877a) using pickit2. when i want to write, it stated that "if you continue, it will difficult to program or erase properly". And i continue..my program was success. But later on, when i want to program a new coding with blank check first, it pop-up again and stated "Program memory is not blanking starting at address 0x000200".
What is the problem? How i can solve it? Thanks..
Farid89ism
