Combat Robot Controller-Arduino Compatib
Postby ArthurWong » Thu Nov 01, 2018 11:17 am
i bought this board this recently (Product Code: URC10), the problem that i face was i cant upload the program after few times upload program. It just state "Uploading" then cant upload the program until now, may i know is there any solution for it?
ArthurWong
Re: Combat Robot Controller-Arduino Compatib
Postby Idris » Thu Nov 01, 2018 4:16 pm
Hi ArthurWong,
Did the problem happened on the first time of usage? Could you share a few clear photos/video on your hardware setup?
Postby ArthurWong » Fri Nov 02, 2018 8:26 am
after few times of usage, i just test the board with the sensor to test functionality, after few times upload program it become "uploading"
ArthurWong
Postby ArthurWong » Sat Nov 03, 2018 12:28 am
may i know what can i do with the board? any solution that i can test or use?
ArthurWong
Postby ober » Sat Nov 03, 2018 5:13 am
Mind sharing the hardware setup?
I would suggest to unplug everything on the board and test loading program again.
Postby ArthurWong » Tue Nov 06, 2018 6:21 pm
ya, that is what i had done, but unfortunately still same, 2 boards gave such problem
ArthurWong
Postby ArthurWong » Wed Nov 07, 2018 10:41 pm
So, may i know is there anything i can do to save the board and need to send back to cytron?
ArthurWong
Postby ober » Thu Nov 08, 2018 11:28 am
Yes, please contact support@cytron.io, our engineers will assist you for warranty.
Postby ArthurWong » Thu Nov 08, 2018 12:58 pm
TQ very much
ArthurWong
