Interfacing waterproof temperature & humidity sensor
Postby ale7beck » Thu Nov 29, 2012 12:14 am
How to interface waterproof temperature & humidity sensor using Intel® Atom™ Processor E6xx Series?
ale7beck
Re: Interfacing waterproof temperature & humidity sensor
Postby robosang » Thu Nov 29, 2012 8:38 am
No idea.... what is the interfacing voltage of Atom processor?? ADC?
Postby ale7beck » Thu Nov 29, 2012 9:17 am
12V external supply. I'm not sure with the ADC but I think it doesn't have one. Is't possible to connect directly?
ale7beck
Postby ale7beck » Thu Nov 29, 2012 11:59 am
I just check another datasheet for Intel Atom E6xx series, it has 2 input 10-bits ADC for signal measurements.
ale7beck
Postby robosang » Fri Nov 30, 2012 9:41 am
You need to know whether it can withstand 5V or 3.3V, because the sensor need that voltage, and if the sensor is analog output, it might output up to 5V.
Users browsing this forum: No registered users and 48 guests
