plz i need help in my bluetooth
Re: plz i need help in my bluetooth
Postby sich » Thu Dec 31, 2009 3:03 pm
IVT Corporation released new version of Bluesoleil(6.4.289.0) which is compatible with Win7:
http://www.bluesoleil.com/download/Detail.aspx?TID=26
I've tested it and it works fine in my Win7. However, this version is NOT free! I'm running on 30 days trial now :(
wavestorm1986, are u using this version too?
Postby wavestorm1986 » Thu Dec 31, 2009 10:06 pm
no i am using differant version which can work k with WIN7
i am using bluesoliel 6.4.249 but with the module cant work at all
do you tried to us an old version for bluesoleil ??? lik version 2.6 ??
if u tried and its k then we flow it, coz i dnt have this version have to download if u have a link plz send it to me
thanx all for the help
wavestorm1986
Postby wavestorm1986 » Mon Jan 04, 2010 8:41 pm
GRAT guys i make it work now
anyway have WIN7 must use bluesoliel IVT2.6.0.8P
this version is working ok
good luck
wavestorm1986
Postby ober » Tue Jan 05, 2010 10:15 am
wavestorm1986, thanks for sharing on your success with us. Keep it up!
Postby wavestorm1986 » Tue Jan 05, 2010 1:14 pm
U R WELCME
wavestorm1986
Postby sich » Tue Jan 05, 2010 2:47 pm
wavestorm1986 WROTE:GRAT guys i make it work now
Great! Can you share the link where you get the installer? Is it a freeware or it requires license?
Postby wavestorm1986 » Sun Jan 10, 2010 3:20 pm
what i did is i bought a dongle and it was supported by mini CD which include the bluesoliel sftware for VISTA, thats y win7 can work slightly like VISTA so at the end it works.
guys i need ur help with something i am willing to buy another bluetooth module which is in the link below
http://www.kcwirefree.com/Default.aspx
my application is sending the ECG signal using bluetooth module so i realize that there are two types data and AUDIO, i am not sure how i can communicate with the audio module coz its not an adapter its a MODULE means i have to bulit the circuit and make it work write????
UART its the best way to handle this but plzzzz i need more guide to make it work IF i bought it....
thanx in advance.....
wavestorm1986
Postby ober » Thu Jan 14, 2010 3:28 pm
wavestorm1986 WROTE: http://www.kcwirefree.com/Default.aspx
Not only the breakout board, but also the other interface to enable audio transmission. I would advise you to go through the data sheet and accessories needed before you decide to get it. We do not have the knowledge in Audio nor codec, thus cannot help you much if you want to transmit the data through Audio link.
Postby wavestorm1986 » Thu Jan 14, 2010 5:54 pm
i went through the data sheet of KC-DEV-5290 and refering to the page 22, i found that i must connect the module and work as a development board, means have to buy the UART to USB and use the pins there to program the module and sure my circuit will be connected to the MIC or INPUT, so this possible ???? something else i tried to order the module and i found that the shipping only is 70$ THIS PRIZE is too much for a student so plz and alternative way to get in cheaper ???
thanx for any advice....
wavestorm1986
Postby ober » Fri Jan 15, 2010 6:50 pm
I am not sure are those what you want as it is out of my field. Not an audio man, cannot help in audio portion. As for the development kit, you can email our sales department and try to get a quotation for it. Yes, shipping is very expensive from US. That's the result why imported items are expensive than their manufacturer.
PreviousNext
