A stupid stupid mistake. Help?
Discussion about online shopping at Cytron website
Postby Jiewy » Fri Jun 18, 2010 8:41 pm
Hie, um this is quite embarrassing but as i were soldering the compass module, the solder was too hot and the copper on the board came off, is there anyway i can send it to u guys for repair? If yes, how much would it be? The ic is still fine though.
Jiewy
Re: A stupid stupid mistake. Help?
Postby ober » Fri Jun 18, 2010 9:49 pm
Can you take a photo and post it here??
Postby shiyan » Sun Jun 20, 2010 10:54 am
is not stupid as long as you learn from the mistake that you have done. Anyway why did you solder the compass board itself? Why do you use header pin?? Luckily you are not soldering the component, it should be the breakout board, right?
shiyan
Postby Jiewy » Tue Jun 29, 2010 8:48 pm
Well i did use header pin but then i realised that i needed to use jumper. so in the process of desoldering the header pin. this happened:-->
how do i add pics here?
Jiewy
Postby sich » Tue Jun 29, 2010 9:23 pm
You'll see this when you reply a post. Choose the file you want to upload and click "Add the file". The file will be attached to the post.
Return to Online Shopping
