Reader Distance?
Reader Distance?
Postby Al-Ameen » Wed Aug 04, 2010 12:44 pm
Hai..i want ask about the distance of reader tag...for the product PR8-B,the distance reader of tag is about 2cm only...my question is can the distance add up until 1meter? what must i do to get the distance about 1m? because my project need the distance of reader tag about 1m...thanks...
Al-Ameen
Re: Reader Distance?
Postby hyng » Wed Aug 04, 2010 1:04 pm
Currently Cytron does not comes out with long distance RFID reader due to the low demand.
Postby Al-Ameen » Wed Aug 04, 2010 5:53 pm
owh...okay..thanks...but,how could i get the distance up to 1 meters? can u give any suggestion to me because i really need that to built my project...did i need to built external antenna?
Al-Ameen
Postby sich » Wed Aug 04, 2010 6:52 pm
Cytron only keep stock of low-frequency (125kHz if not mistaken) RFID system (reader & card) which works for short range transmission (few cm). Longer range transmission is only possible at higher frequency. What you need is a different system from the one provided by Cytron.
Postby Al-Ameen » Thu Aug 05, 2010 2:51 am
you : What you need is a different system from the one provided by Cytron..
me : what system is suitable that provided by cytron?
Al-Ameen
Postby sich » Fri Aug 06, 2010 1:11 am
Al-Ameen, what i mean is Cytron doesn't have the solution that meets your requirement. So you may need to find solution from other sources if you need RFID system with 1 meter transmission distance.
Return to RFID
