how to connect UC00A to Xbee
Postby shuraj » Thu Sep 09, 2010 9:49 am
Can UC00A be a subsitute for Xbee USB explorer?If yes how do i connect it to a Xbee?
shuraj
Re: how to connect UC00A to Xbee
Postby yonghui » Thu Sep 09, 2010 12:32 pm
UC00A can be used to interface Xbee to computer with XCTU software.
refer user manual of xbee, page 7
• Minimum connections: VCC, GND, DOUT & DIN
• Minimum connections for updating firmware: VCC, GND, DIN, DOUT, RTS & DTR
so depending whether u will like to do some firmware update onot, if yes, then u will connect it the 2nd way so that we can communicate and also update the firmware.
be careful doing the connections, make sure of 3.3V, becoz xbee modules operate at 3.3V, set the jumper at UC00A to 3.3V and u might wan to do some protection with small value of resistors.
Postby robosang » Tue Sep 14, 2010 9:18 am
I think the hard part will be the level shifter between 5V and 3.3V. To get 3.3V power you can use 3.3V voltage regulator, but for signal, it might be more complex. Try to google and see is there any solution?
Postby davidtsj » Tue Mar 15, 2011 11:55 pm
Dear robosang,
I would like to ask bout UC00A too as it's hard to find in internet that shows the schematic connections between the Uc00A and xbee to pc...what do u mean by signal..juz convert 5V to 3.3 V is not enough?thx in advance
davidtsj
