help me with my GUI SC08A..
Postby angelo » Sun Sep 11, 2011 1:57 am
i tried to connect my servo using sc08a - usb to uart thru GUI but when i press the button "active 8" it just freeze. what is the problem actually?
angelo
Re: help me with my GUI SC08A..
Postby hyng » Mon Sep 12, 2011 10:58 am
Hi, what you mean by freeze? is the servo HOLD on its position? It is normal if the servo motor turn to initial position and hold at that position. After that, did you try to adjust the slide bar? is the servo move according to the slide bar? Or you mean the GUI program "hang"?
Postby shiyan » Tue Sep 13, 2011 11:48 pm
I think he meant the GUI "hang", it might be the communication problem? SC08A is servo controller? How is being connected to computer?
shiyan
Postby angelo » Wed Sep 14, 2011 8:21 am
sorry, the GUI program "hang" when i press "active 8". cant move the slide because the GUI program "hang" .the servo only move when i press the "test" button on SC08A. i connected the hardware to my laptop according to SC08A manual. any idea to solve this problem?
angelo
Postby hyng » Thu Sep 15, 2011 11:43 am
Is the USB to SC08A connection correct? Is PC able to detect the comport, do not choose the wrong comport? And the TX and RX line from UC00A/B (if you are using this) to SC08A is correct?
The program "hang" most probably due to the connection between SC08A and computer.
Postby angelo » Thu Sep 15, 2011 8:12 pm
usb to sc08a is connected correctly and yes my laptop can detect the comport. i tried so many time but still doesnt work. what is the recommended software & hardware to connect with my sc08a beside GUI? i'm doing a simple robot arm using 6 servo. im new at electronics and need help with this. thanks
angelo
Postby shiyan » Fri Sep 16, 2011 10:21 am
angelo WROTE:usb to sc08a is connected correctly and yes my laptop can detect the comport. i tried so many time but still doesnt work. what is the recommended software & hardware to connect with my sc08a beside GUI? i'm doing a simple robot arm using 6 servo. im new at electronics and need help with this. thanks
A printscreen of the laptop and a photo of the setup might be useful I think... What is the USB to SC08A connection?
shiyan
Postby angelo » Wed Sep 28, 2011 6:38 am
the USB to SC08A is UC00A.
angelo
Postby hyng » Wed Sep 28, 2011 5:05 pm
Yes, a photo of the setup might be useful. The connection between UC00A and SC08A must be correct, UC00A's TX to SC08A's RX and UC00A's RX to SC08A's TX. There are few cases which users connect the wire wrong causing the GUI hang, eventhough computer can detect the comport. However, if you sure the connection is correct, you can request for warranty and we will verify the causes. Please fill in the form in the support tab which located at Cytron page. Our support team will reply you as soon as possible.
Postby angelo » Wed Sep 28, 2011 8:49 pm
ok.. the SC08A works now. now i know the problem is the RX & TX connection. thanks. :)
angelo
