PIC Control Light Dimmer
Postby TeoYX » Sun Oct 02, 2011 5:00 pm
Is this circuit suitable for PIC PWM pin to control the light intensity?
Light Dimmer.jpg (3.54 KiB) Viewed 2369 times
Does anyone try use PIC to control light before? Please advise. Thanks a lot.
TeoYX
Re: PIC Control Light Dimmer
Postby zhenning » Sun Oct 02, 2011 5:12 pm
yes, it should be able to :)
zhenning
Postby TeoYX » Sun Oct 02, 2011 5:50 pm
zhenning WROTE:Hi,
Did u do this before? Using the normal transistor will do? I also don't know how to select the resistor for this circuit, can teach me how?
TeoYX
Postby zhenning » Sun Oct 02, 2011 9:22 pm
depending on what light dimmer you want to do. AC dimmer, you need to use triac while small bulb or led, you can use any transistors :)
zhenning
