how to increase Rx/tx range
Postby hazzam » Tue Oct 18, 2011 12:30 pm
hai...i'm doing my project using my pt2272 and pt2262 in the wireless project...the problem is,the range in the theory that i read is 10m. but,after assemble the component and i had it tested, it range goes only 10cm. and for my project, i had to increase the range above 10m. so, how can i amplify the range or increase the range. can u please give me some idea about it..
hazzam
Re: how to increase Rx/tx range
Postby yonghui » Tue Oct 18, 2011 2:59 pm
ur antenna is properly solder ? how long?
i try the low cost module, it can at least reach 5m without antena.
Postby hazzam » Tue Oct 18, 2011 3:36 pm
i used 8cm length for the antenna. so in order to increase the range, we must increase the antenna length?? is that u mean??
hazzam
Postby robosang » Wed Oct 19, 2011 7:51 am
I think it has to do with wave length
Postby yonghui » Wed Oct 19, 2011 10:37 am
are u sure all ur connections are correct?
10cm seems something wrong.
what is the voltage u use?
Postby hazzam » Wed Oct 19, 2011 1:17 pm
for tx i used 12vdc and for the rx iused 5vdc..
hazzam
Postby low5545 » Thu Oct 20, 2011 7:30 pm
are you using RF modules?
low5545
Postby ober » Sun Oct 23, 2011 9:54 pm
A photo of your setup is great. Anyway a fast check.... the transmitter and receiver power supply, is using adapter or battery?
Postby low5545 » Tue Oct 25, 2011 4:17 pm
According to the User's manual on http://www.cytron.com.my/datasheet/WirelessDevice/RF_TX_User%27s_Manual.pdf and http://www.cytron.com.my/datasheet/WirelessDevice/RF_RX_User%27s_Manual.pdf, the antenna length of the 315MHz Transmitter and Receiver must be at 24cm, while the 433MHz at 18cm. Hope this helps.
low5545
Return to Misc Project
