unable to communicate with modem
Postby mohamad_taib » Tue Oct 25, 2011 4:13 pm
Hi all,
i'm keep receiving this messege " unable to communicate with modem" each time i click on test/query tab on X-CTU software..
the baudrate is 9600..
any advice?
Thanks!
mohamad_taib
Re: unable to communicate with modem
Postby mohamad_taib » Tue Oct 25, 2011 4:18 pm
i'm using xbee pro + sheild + arduino duemilanove
mohamad_taib
Postby tonywk88 » Thu Oct 27, 2011 10:35 pm
Did you change the jumper for (XBEE/USB) jumper to XBEE while trying to communicate ?
tonywk88
Postby hyng » Fri Oct 28, 2011 5:54 pm
Hi, is your PC detect the comport? Do you choose the right comport?
Are you using SKXBee-Pro or just the XBee-Pro module? Please bear in mind that the XBee must in 3.3V voltage level, else the module might spoilt.
Postby mohamad_taib » Fri Oct 28, 2011 10:01 pm
thanks for the reply,
i believe the com port is correct as well as the usb/xbee jumper.
i'm using xbee pro with xbee shield and arduino board(with the ic removed).. only after several retries, i manage to establish the connection. but sometimes i cannot communicate at all..
mohamad_taib
Postby sich » Tue Nov 01, 2011 10:34 am
mohamad_taib WROTE:i'm using xbee pro with xbee shield and arduino board(with the ic removed)
Can you clarify this? Why do you need an Arduino board with the IC removed? Loose connection should be the root cause.
