Line follower robot using PID controller??
Postby are_kym » Sat Aug 07, 2010 1:11 am
I want to make a line follower robot using PID controller for my FYP. How can i attach the circuit of IR sensor to the PID controller because as i know, there is no port for IR sensor in the PID controller... Plz help me...
are_kym
Re: Line follower robot using PID controller??
Postby shiyan » Sat Aug 07, 2010 2:09 pm
are_kym WROTE:How can i attach the circuit of IR sensor to the PID controller because as i know, there is no port for IR sensor in the PID controller... Plz help me...
What type of PIC controller are you using? Frankly speaking, never heard a PID controller that specially designed for line following... :shock:
shiyan
Postby mhdi » Thu Nov 24, 2011 3:01 pm
can someone help me to program PID controller in PIC16F877A.... :idea:
mhdi
Postby low5545 » Thu Nov 24, 2011 5:15 pm
What's a PID?
low5545
Postby Brian Griffin » Thu Nov 24, 2011 6:46 pm
low5545 WROTE:What's a PID?
Proportional-Integral-Derivative.
If you are studying in an engineering course in a college, you may bump into this a lot. :)
Postby mhdi » Thu Nov 24, 2011 9:31 pm
i want to know how to program PID in my line follower mobile robot...
hope someone who is pro can help... plz :)
mhdi
Postby robosang » Fri Nov 25, 2011 9:27 am
Maybe you should try Cytron DIY project, I did see some one asking about PID, not sure whether is for line following. Let me take a look.....
OK, is not line following, is a motor positioning control. Yet, I think the concept is similar, try to look at the source code and study it, the DIY project is PR24.
Postby low5545 » Fri Nov 25, 2011 1:25 pm
Discontinued though.
low5545
Postby mhdi » Sun Nov 27, 2011 11:22 pm
Thank you robosang... :D
i will study it
mhdi
Postby holy_rainman » Sat Dec 17, 2011 12:02 am
Mhdi, are you still doing this project? any luck?
holy_rainman
