Servo Controlling using PIC16F877A
Servo Controlling using PIC16F877A Need HELP (URGENT)
Postby aqish88 » Sat Dec 03, 2011 1:01 am
hello everyone.. need some help..
I'm using PIC16f877a to control the servo motor
and my problem is.. when I combine my servo motor cooding, the motor is not function on circuit board..
but when i'm using proteus for testing, the motor run smoothly.. what should i do..?!
this is my induvidual cooding to control servo motor..
-MicroC-
void main(void)
TRISB = 0xFF;
TRISC = 0x00;
PORTC = 0x00;
Pwm1_Init(10000);
while(1)
if (PORTB.B0 == 0)
Pwm1_Set_Duty(255); //50% Duty Cycle for forward
Pwm1_Start();
else if (PORTB.B1 == 0)
Pwm1_Set_Duty(127); //25% Duty Cycle for reverse
Pwm1_Start();
aqish88
Re: Servo Controlling using PIC16F877A
Postby robosang » Mon Dec 05, 2011 11:05 pm
Are you controlling standard RC servo? It seem to be modified servo :mrgreen:
Postby aqish88 » Tue Dec 06, 2011 12:17 am
I'm using C36R.. I'm studying the data sheet but the problem is it's not moving when i applying it for my full cooding system..
aqish88
Postby hyng » Wed Dec 07, 2011 1:36 pm
There is a sample source code under the C36R product page. You can refer to it. Although the sample code is written in C with Hitech C compiler, the basic concept is the same.
Previous
