PWM for PIC16f877A
PWM for PIC16f877A
Postby TeoYX » Thu Mar 01, 2012 8:55 am
Hi all,
I am using PIC16f877A to control 2 PWM outputs, which is RC1 and RC2. Below are the sample program for both PWM:
#define fanA RC1
#define fanB RC2
CCP2CON = 0b00001100; //PWM Mode
//PWM frequecy set as 4.88KHz
PR2 = 0xFF; //PWM Period Setting
T2CON = 0b00000101; //Timer2 On, prescale 4
//High Speed
CCPR1L = 255;
delay(5000);
fanA=1;
CCP1CON = 0b00001100; //PWM Mode
//High Speed
CCPR2L = 255;
delay(5000);
fanB=1;
Here is the connection for the fanA and fanB
PWM Output Connection.JPG (4.32 KiB) Viewed 3478 times
I measured the voltage output from RC1 and RC2 only get 0.05V only with 255. Is the 255 maximum value for the PWM? Don't it should be output 5V?
Please advice. Thanks a lot.
PWM Output Connection 2.JPG (3.12 KiB) Viewed 3478 times
TeoYX
Re: PWM for PIC16f877A
Postby robosang » Fri Mar 02, 2012 10:39 pm
How about TRISC?
Postby TeoYX » Sat Mar 03, 2012 10:05 am
TRISC = 0b11011001; where RC1 and RC2 are set to be output.
TeoYX
Postby robosang » Mon Mar 05, 2012 3:27 pm
Can you verify the code and hardware at least can execute program? Have you load the program in to PIC (sorry to ask, but many beginner din load the code) :mrgreen:
Postby ABSF » Tue Mar 06, 2012 9:59 am
TeoYX WROTE:I measured the voltage output from RC1 and RC2 only get 0.05V only with 255. Is the 255 maximum value for the PWM? Don't it should be output 5V?
50mV is not enough to make the transistor conduct. What is the voltage at the Collector to Ground?
Something is wrong with your program. Did you try with the sample code from cytron that is used to operate DC motors?
Postby TeoYX » Tue Mar 13, 2012 12:40 am
Problem solved. There is circuit connection problem. Haha. Thanks a lot for your reply. Thanks...
TeoYX
