Connection for 8 pin PIC12F675 at uic000B
Postby akim9903 » Wed Apr 11, 2012 6:24 pm
Anybody can help me. I'm going to program PIC12F675 IC but the adaptor is cater for 18pin & 28/40pin type.
Can explain the connection to me. very-very urgent.
thank you.
akim9903
Re: Connection for 8 pin PIC12F675 at uic000B
Postby ABSF » Wed Apr 11, 2012 8:49 pm
Refer to this tutorial on how to connect UIC00B to 12F675. Would be easier if you got UIC-A.
A PIC 12F675 tutorial.
http://www.best-microcontroller-project ... onnections:
Postby akim9903 » Thu Apr 12, 2012 8:16 am
Not really understand. Can modify from UIC-S adaptor?
akim9903
Postby hyng » Thu Apr 12, 2012 10:41 am
The adapter you mean is UIC-S? In this case the UIC-S will not help. You have to pull out the programmer pins from the PIC to ICD box header as shown in the figure at page 38 of the User's Manual. The ICD Box Header 2x5 is http://www.cytron.com.my/viewProduct.php?pcode=CN-IDC-BOX-10&name=10%20Ways%20Straight%20Box%20Header Then you can connect the programmer cable of UIC00B to that box header.
Postby ABSF » Fri Apr 13, 2012 6:48 am
UIC00B 10 pin Box plug
UIC-A adaptor
Plug the 10 pin box plug from UIC00B to UIC-A then refer to the diag below:
UIC-A to 12F675 connection
