Connection between H/P and PIC 876A?
Postby sse » Thu Mar 22, 2012 8:30 pm
Hello everyone!
What is the easiest way to get the connection between pic16f876A with nokia hp 6610(or any suggestion?)
Im fresh to PIC~ :twisted:
Please, i want to know the specific terminal connection between h/p & pic?? 8-)
THANKS ALL~
sse
Re: Connection between H/P and PIC 876A?
Postby shahrul » Thu Mar 22, 2012 8:48 pm
It's hard to learn the interfacing. As I know, sometimes it's different interfacing between different model. Also it's hard to find the reference maybe because Nokia company not given that for hobbyist.
Postby ABSF » Fri Mar 23, 2012 9:12 am
sse WROTE:What is the easiest way to get the connection between pic16f876A with nokia hp 6610(or any suggestion?)
There is no easy way to connect a handphone to the PIC. You have to do a lot of hacking on the phone in order to succeed. You'll understand what I meant if you refer to the discussion here:
viewtopic.php?f=21&t=11255
An easier way is to use a GSM Modem.
http://www.cytron.com.my/listProducts.php?actionURL=&txtSearch=gsm+modem
GSM SIEMENS TC35 SMS Wireless Module UART/232 | eBay
http://www.ebay.com/itm/GSM-SIEMENS-TC35-SMS-Wireless-Module-UART-232-/200524455404?pt=LH_DefaultDomain_0&hash=item2eb0305dec#ht_5320wt_781
NEW GSM SIEMENS TC35 SMS Module Board RS232 UART Serial Arduino + Voice adapter | eBay
http://www.ebay.com/itm/NEW-GSM-SIEMENS ... 4128wt_805
refer to the project done by En. Idris using TC35:
http://forum.cytron.com.my/viewtopic.php?f=30&t=11502
Postby sse » Fri Mar 23, 2012 9:54 pm
hello,
How much for a GSM modem in Ringgit Malaysia? any other accessory for this GSM modem when connect with 877A? or any extra program need to install?
THANK YOU~
sse
Postby sse » Fri Mar 23, 2012 10:12 pm
is it possible if get a signal from 877A to make the GSM Modem call somebody(ATD><mem><n> Originate call to phone number in memory <mem>)?
Thanks~
sse
Postby ABSF » Sat Mar 24, 2012 5:00 pm
sse WROTE:is it possible if get a signal from 877A to make the GSM Modem call somebody(ATD><mem><n> Originate call to phone number in memory <mem>)?
From the Cytron Modem, the user manual said:
B. Dial call or receive call (Modem doesn’t provide voice port even with relevant
command)
1. Dial call ATDxxxxxxxxx; (xxxxxxxxx is phone number,example:ATD1860;)
2. Call waiting function:AT+CCWA
3. Hold function:AT+CHLD=?
4. Dial latest call number:AT+CLCC=?
5. Enter information once connection established(DTMF):AT+VTS=(0-9,#,*,A-Z)
As for the TC35 modem, voice port is provided but you have to add the MIC and RECEIVER yourself. Did you download the datasheet from the ebay site that I gave you? Lots of info is there on the datasheet... There are software examples for 8051, AVR and VB too.
Postby Idris » Sun Mar 25, 2012 8:54 am
Yes, it is possible. Need to program the 877A, if receive the signal then call somebody. There have a lot of GSM project and sample code. Actually what kind of project you want to do?
Postby sse » Sun Mar 25, 2012 9:36 am
HI,
okay, I'll do the research~~ BTW, how much for the GSM module?
TQ
sse
Postby sse » Sun Mar 25, 2012 10:18 am
hello,
I'm going to do the wireless smoke detector with some modify~
START-->sensors detected-->encoder-->Tx-->Rx-->decoder-->PIC-->LCD & CALL;
im thinking that to use 3 sensors in 3 rooms respectively, and 3 encoders & decoders to a PIC.
The PIC will connect to a LCD. When 1 of sensor detected, the LCD will shows which room detected~
At the same time, it can be call and inform the person in charge.
Well, as ur experiences, i need ur comment~
first at all, im not familiar with pic program~
maybe i'm confusing with the connection between decoder to pic and the connection between pic to phone call system~
thanks!
sse
