Fuzzy Logic to C
Fuzzy Logic to C
Postby JDM » Wed Oct 31, 2012 7:09 am
Hi everyone.
Suppose that i've created the following Fuzzy control in Matlab, where the output will be the number of time in seconds.
And from googling so many time, i found this useful website that can translate the Fuzzy control from Matlab to C code that is useable to Arduino. Here's the link: http://makeproto.com/blog/?p=35
I name my Matlab file as tankps.fis. Here's the translated code in C:
#include "tankps.h"
// Not Function
float _not(float x)
   return (float)(1.0-x);
// Generates the values in the range [min,max] with increments
// defined by 'step'.
void generate(float minimum, float maximum, float st, float* values,int length)
   float x = minimum;
   int i;
   for(i=0;i<length;i++,x+=st)
      values[i] = x;
// Sets all elements in the array with the same value
void set(float* values,int length,float value)
   int i;
   for(i=0;i<length;i++)
      values[i] = value;
// Product of elements in an array
float prod_array(float* x, int length)
   float m = 1;
   int i=0;
   for(;i<length;i++)
      m *= x[i];
   return m;
// Probabilistic OR
float probor(float* x, int length)
   float m = 0;
   int i=0;
   for(;i<length;i++)
      m = m + x[i] - m*x[i];
   return m;
// Centroid of points
void centroid(float* x, float* y, int length, float* Cx, float* Cy)
   float a = 0;
   float tx = 0;
   // float ty = 0;
   float t = 0;
   int i = 0;
        int l = length - 1;
   for(;i<l;i++)
      t = ((x[i] * y[i+1]) - (x[i+1] * y[i]));
                a += t/2;
      tx = (x[i] + x[i+1]) * t;
      // ty = (y[i] + y[i+1]) * t;
   *Cx = (tx /(6 * a));
   // *Cy = (ty /(6 * a));
// Gaussian Member Function
float gaussmf(float x, float s, float c)
    float t = x-c;
    return _exp(-(t * t) / (2 * s * s));
// Triangular Member Function
float trimf(float x, float a, float b, float c)
    return (float)max(min((x - a) / (b - a), (c - x) / (c - b)), 0);
// Aggregation code for membership functions that require 2 setting values
void aggregate2(float* rules, int* ruleIndexes, int ruleIndexLength, float* xArr, float *yArr, int resultLength,_mffloat2 mf,float a,float b)
   int i=0, j=0;
   for(;i<resultLength;i++)
      for(j=0;j<ruleIndexLength;j++)
         float t = rules[ruleIndexes[j]] * mf(xArr[i],a,b);
         yArr[i] = yArr[i] + t - yArr[i]*t;
// Aggregation code for membership functions that require 3 setting values
void aggregate3(float* rules, int* ruleIndexes, int ruleIndexLength, float* xArr, float *yArr, int resultLength,_mffloat3 mf,float a,float b,float c)
   int i=0, j=0;
         float t = rules[ruleIndexes[j]] * mf(xArr[i],a,b,c);
void tankps(float* inputs, float* outputs)
{   // Transformation of inputs to fuzzy inputs.
   // Input variable input
   float Inputs1[3];
   // Input term 'sink'for variable 'input'
   Inputs1[0] = gaussmf(inputs[0],0.3,-1);
   // Input term 'null'for variable 'input'
   Inputs1[1] = gaussmf(inputs[0],0.3,-2.776E-17);
   // Input term 'rise'for variable 'input'
   Inputs1[2] = gaussmf(inputs[0],0.2998,1);
   // Input variable level
   float Inputs2[3];
   // Input term 'sinking'for variable 'level'
   Inputs2[0] = gaussmf(inputs[1],0.03,-0.1);
   // Input term 'none'for variable 'level'
   Inputs2[1] = gaussmf(inputs[1],0.03,-1.301E-18);
   // Input term 'rising'for variable 'level'
   Inputs2[2] = gaussmf(inputs[1],0.02998,0.1);
   // Build all the conditions.
   // Variable to store the condition result
   float R[5];
   float CondR[2];
   // Handle conditions for rule 1
   CondR[0] = Inputs1[1];
   R[0] = 1 * prod_array(CondR,1);
   // Handle conditions for rule 2
   CondR[0] = Inputs1[2];
   R[1] = 1 * prod_array(CondR,1);
   // Handle conditions for rule 3
   CondR[0] = Inputs1[0];
   R[2] = 1 * prod_array(CondR,1);
   // Handle conditions for rule 4
   CondR[1] = Inputs2[2];
   R[3] = 1 * prod_array(CondR,2);
   // Handle conditions for rule 5
   CondR[1] = Inputs2[0];
   R[4] = 1 * prod_array(CondR,2);
   // Basic output processing
   int res = 100;
   float step;
   float xMin;
   float xMax;
   float x[res];
   float y[res];
   float t;
   int value[5];
   // Output variable valve
   xMin = 0;
   xMax = 10;
   t=0;
   step = (xMax - xMin) / (float)(res - 1);
   generate(xMin, xMax, step, x, res);
   set(y, res, 0);
   value[0] = 2;
   aggregate3(R,value,1,x,y,res,trimf,0,0.5,1);
   value[0] = 3;
   aggregate3(R,value,1,x,y,res,trimf,2,2.5,3);
   value[0] = 0;
   aggregate3(R,value,1,x,y,res,trimf,4.5,5,5.5);
   value[0] = 4;
   aggregate3(R,value,1,x,y,res,trimf,6,6.5,7);
   value[0] = 1;
   aggregate3(R,value,1,x,y,res,trimf,9,9.5,10);
   centroid(x, y, res, &outputs[0], &t);
Well now my problem is, i don't know how to access the inputs and output of the translated code. The instruction given (on the link) in step 5 is to create an array of inputs and an array of outputs. I don't understand the step 6, which it says:
Call the system function with a pointer to the inputs and a pointer to the outputs (the function will have the same name as your .FIS file).
HELP please! =(
JDM
