recommendation RF to control home appliances .
Re: recommendation RF to control home appliances .
Postby yonghui » Thu Oct 11, 2012 11:47 am
it depends on what controller u are goin to use to communicate with the xbee. if computer, then u know what to use, any software that can access to serial com port. if microcontroller, its depends on what controller u are goin to use.
if PIC then u can use mplab/mplabx, with the free compiler provided by microchip.
Postby dell » Tue Nov 06, 2012 1:14 am
hi ,im new here..
im planning to do bluetooth project,to control home appliances too.
using android apps (can suggest which apps is better)
im thinking serial terminal
about the hardware,which one can connect multiple bluetooth?
example,im using android apps to control multiple of bluetooth connection(possible?).
besides this bluetooth module,do i need others like microcontroller,relay, etc?
how many days to ship the things too Kuala Lumpur?
thank you in advance.
dell
Postby robosang » Tue Nov 06, 2012 8:48 pm
Not sure on the multiple connections, but you will need a microcontroller to process the serial data and decide what to do.
Normally I get my order in 1 day, working day :) Cytron use Skynet to send orders.
Postby dell » Tue Nov 06, 2012 10:43 pm
robosang WROTE:Not sure on the multiple connections, but you will need a microcontroller to process the serial data and decide what to do.
tq for ur reply,
example..
im using 1 module of bluetooth, to connect 2 or 3 connection (through same bluetooth module)
im planning to control switches (wall plug/switches).
is it possible?
how to order?just follow the step ordering ? and use my address in malaysia right?.
thank you
dell
Postby zhenning » Wed Nov 07, 2012 10:24 pm
thank you
Just login and follow the steps to order. use your address where you want them to send to you.
zhenning
Postby ober » Wed Nov 07, 2012 10:49 pm
Hi, you can refer to our FAQ page for the steps to place order and make payment. As zhenning said, just put the address where you want the order to be sent to.
Postby sahniana » Tue Dec 11, 2012 3:43 pm
i recommend other than RF, higher cost but better :D
sahniana
Previous
