adruino uno & bluetooth module.
Postby mohd » Tue Dec 04, 2012 12:00 pm
can Arduino uno be connected to cytron bluetooth module without using shield? if it can, how?
mohd
Re: adruino uno & bluetooth module.
Postby zhenning » Tue Dec 04, 2012 12:08 pm
mohd WROTE:can Arduino uno be connected to cytron bluetooth module without using shield? if it can, how?
Attached is the cytron bluetooth pinout:
http://tutorial.cytron.com.my/2011/08/13/getting-started-with-bluetooth-bee/tel0023_pinout/
Yes you can. Connect the power supply. 3.3V and GND. There are 2 modes of communication: SPI and UART. Depends on which, you connect accordingly.
zhenning
Postby mohd » Tue Dec 04, 2012 7:28 pm
if i use UART mean i will use Tx and Rx only? will it affect to programing if im not using shield??
mohd
Postby zhenning » Tue Dec 04, 2012 7:45 pm
Yes. it will even be the same if you use the shield. It is also connected to the tx and rx
zhenning
