Connecting two Xbee Series 1 in API mode
Postby MarwanShaheen » Sun Dec 16, 2012 3:11 pm
Dear all,
I was hoping that someone can help me through this. I have two xbee S1 modules and i want them to chat between each other using terminal program. however they need to be set in API mode (API mode 2 would be better) because i was unable to set them to chat between each other when i put the settings:
PAN ID: 1111
coordinator MY: 1234
end device MY: 5678
API mode: 2
Baud rate: 9600 both sides
i have put destination addresses of each other : coordinator destination address: 5678, end device destination add: 1234
your help would be so awesome
MarwanShaheen
Re: Connecting two Xbee Series 1 in API mode
Postby robosang » Tue Dec 18, 2012 9:48 pm
Why need to be in API2??
Normal transparent mode is good enough for serial communication.
Postby MarwanShaheen » Thu Dec 20, 2012 12:03 pm
That's because i needed to retrieve the RSSI value from the packets. the value is presented better by API mode formatted packet.
I got it working after all thank you for replying.
MarwanShaheen
