Help !! I was using UIC00A and im try do work on debugger mode. I mistakenly supply external and internal supply to my board, but after that i made adjustment it work smoothly. But, on the next day suddenly UIC00A cant be detected !! Did i burn it ? (the green light is still on)
thz for reply !! i dont thk device manager have it, bcoz it dont even have the pop up USb thing. how to reinstall the driver, bcoz i didnt install it at the 1st place ?
Look inside the device manager. It should show all connected devices. It there is no driver, then you will see a yellow question mark. If the driver is installed, uninstall it
i tried plug and unplug the programmer while looking at the device manager, nothing pop up. But when i replace UIC00A with UIC00B, it work fine. So, i need to know how to make sure that UIC00A burned ? with the green light still on. Or did i accidently erase smthg in it ?
