Need help on programming code count 00 to 99
Postby Fiz » Sun Mar 17, 2013 10:59 am
Hello,
i have problem to write programming code in MikroC Pro for PIC,since i'm quite new in micro c and programming,i do not know what my programming code mistake,btw i'm using PIC16F877A. Here i attach my code,hope someone can guide me,really appreciate it.
int i,j,k;
void display_s1(int j,int i){
PORTB = 0b00100000 + j;
PORTB = 0b00010000 + i;
delay_ms(2);
void main() {
   TRISB = 0;
   PORTB = 0;
   while(1){
        for(k=0;k<100;k++){
        j = k%10;
        i = k/10;
        display_s1(j,i);
        delay_ms(200);
Fiz
Re: Need help on programming code count 00 to 99
Postby Fiz » Sun Mar 17, 2013 11:06 am
This is my another coding,also cant get nice count 00 to 99 because the 7-segments are alternating count.
int i,j,k;
void display_s1(int j){
delay_ms(2);
void display_s2(int i){
delay_ms(2);
void main() {
   TRISB = 0;
   PORTB = 0;
   while(1){
        for(k=0;k<100;k++){
        j = k%10;
        i = k/10;
        display_s1(j);
        delay_ms(200);
        display_s2(i);
        delay_ms(200);
Fiz
Postby shahrul » Sun Mar 17, 2013 3:32 pm
How your schematic?
Postby Fiz » Sun Mar 17, 2013 4:28 pm
Here my schematic,sorry for not include it earlier
Fiz
Postby shahrul » Sun Mar 17, 2013 6:20 pm
I will use Timer Interrupt for the multiplexing and put transistor switching on common seven segment.
Postby Fiz » Sun Mar 17, 2013 6:35 pm
Hello,
Thanks for your feedback,timer interrupt..something new,i'll try,thanks again
Fiz
Postby Brian Griffin » Sun Mar 17, 2013 7:54 pm
I do not see a lookup table there. Depending on the connection of the 7-segment, your lookup table will be different. Therefore,
const unsigned char sevenSegment[10] = { ... }
keeps all your patterns for each number per digit.
Then, to multiplex it, you
while(1) {
1.) turn digit 1 on, and turn digit 2 off
2.) put digit (10s) into PORTB, like sevenSegment[x] where x is the number. If it's 1, then it'll show up one.
3.) delay for 1-5ms
4.) turn digit 1 off, and turn digit 2 on
5.) put digit (1s) into PORTB, like sevenSegment[x] where x is the number. If it's 1, then it'll show up one.
6.) delay for 1-5ms
There's also the timer and interrupt trick as Shahrul said. You can use that as well. This sample pseudocode is just for understanding only.
Postby robosang » Tue Mar 19, 2013 10:14 am
Yup, agreed with Shahrul where transistor is needed because the current required to be absorb is more than what single PIC pin can take.
what is the common polarity of the 7segment? Common anode or cathode? Is the 74 chip decoder?
