CR038 - R/W RFID Programming Problem!!!
Postby khairul » Fri Apr 05, 2013 10:17 pm
Assalamulaikum (peace to all)... i have problem to read data from Mifare card.. I have develop the programming, currently i can Activate the Antenna and blink the LED on CR038 RFID R/W Module.. But i cannot access the data from Mifare Card (Card type, NUID and other parameter) although i apply the same concept to access data from the Mifare card.
Can anyone help me..
khairul
Re: CR038 - R/W RFID Programming Problem!!!
Postby robosang » Sun Apr 07, 2013 1:58 pm
So us what have you done
Postby khairul » Tue Apr 09, 2013 1:48 pm
Sorry for late reply, currently i have made coding to read NUID from the card. the problem is i cannot use the function to select card using NUID.
void CR038_SELECT_CARD(void)
        // 1) On Antenna
   UART_SEND(0xAA);
   UART_SEND(0xBB);
   UART_SEND(0x06);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0X0C);
   UART_SEND(0X01);
   UART_SEND(0X01);
   UART_SEND(0X0C);
   for(a=0;a<=9;a++)
      reply[a] = UART_REC();
       // 2) Card Type
   UART_SEND(0xAA);
   UART_SEND(0xBB);
   UART_SEND(0x06);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x01);
   UART_SEND(0x02);
   UART_SEND(0x52);
   UART_SEND(0x51);
   for(a=0;a<=11;a++)
   // 3) Anti Collision
        UART_SEND(0xAA);
   UART_SEND(0xBB);
   UART_SEND(0x05);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x02);
   UART_SEND(0x02);
   UART_SEND(0x00);
   for(a=0;a<=13;a++)
   // 4) Select Card
   UART_SEND(0xAA);
   UART_SEND(0xBB);
   UART_SEND(0x09);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x00);
   UART_SEND(0x03);
   UART_SEND(0x02);
   UART_SEND(0x0E); // NUID[0] : LSB : 0x0E
   UART_SEND(0x8B); // NUID[1]       : 0x8B
   UART_SEND(0xE4); // NUID[1]       : 0xE4
   UART_SEND(0x27); // NUID[1] : MSB : 0x27
   UART_SEND(0x47); //XOR or Checksum
   for(a=0;a<=10;a++)
//UART Function
void UART_SEND(unsigned char data)
   while(PIR1bits.TXIF==0);
   TXREG=data;
unsigned char UART_REC(void)      //function to wait for a byte receive from uart
   if(RCSTAbits.OERR == 1) // If OverRun Error Occure
      RCSTAbits.CREN=0;
      RCSTAbits.CREN=1;
   while(PIR1bits.RCIF==0); //wait for data to received
   return RCREG;   //return the received data
khairul
Postby khairul » Tue Apr 09, 2013 2:10 pm
oh BTW i can read NUID from the card, my problem is i cannot use the NUID to select the card for future development such as Read or Write...
What i have done for Troubleshooting
1) i have check the XOR
khairul
Postby khairul » Wed Apr 10, 2013 2:03 am
Hai, sorry again, i have solve the problem i have before this. anyways thanks to everyone who view and try to solve it..
khairul
Postby robosang » Wed Apr 10, 2013 11:36 am
Good to hear that. Mind to share the result and what is the root cause?
Postby khairul » Wed Apr 10, 2013 12:22 pm
Ok... i try to post all
khairul
Postby khairul » Wed Apr 10, 2013 1:13 pm
Assalamulaikum (Peace to All)..
Here are source code and schematic for my CR038 project...
Hardware Details
1) I use PIC18F2520 with MPLAB IDE v7.43 + MCC18 C Compiler
2) 16x2 LCD Display
3) 4 Push Button (I only use 3 out of 4)
4) 1 UART Port
5) ... Details circuit in the schematic
Programming Details
Inside the attachment, there are library to support MAIN.c
Programming Troubleshooting
1) PROBLEM : when i send command from PIC to CR038 and try to display data from CR038 nothing display.
SOLUTION : double check data that you send through UART and please triple check the XOR or Checksum.
2) PROBLEM : CR038 does not response to cmd that you transmit from PIC.
SOLUTION : Please Activate the ANTENNA and after u WRITE or READ Disable it..
DO NOT place your card inside the plastic that cytron give. i do not know why but it will make the CR038 cannot read the Mifare Card
CR038 Project.rar
Schematic and Programming
(20.6 KiB) Downloaded 1648 times
khairul
Postby khairul » Mon Apr 15, 2013 1:46 pm
Hai all, i want to improve this project,
before this for Read operation i use a Push button. So i want to improve to auto read card within the range just like RFID : http://www.cytron.com.my/viewProduct.ph ... 232%20(New)
the problem is i don't have any idea how to improve it.. can anyone share something with me.
khairul
Postby hairizam » Wed Sep 11, 2013 2:21 pm
i want to use CR038 in my final project..can u explain about CR038 because i dont understant how its function and how to write to the card
hairizam
Return to RFID
