shahrul WROTE:I always use External Interrupt to read the pulse and Timer Interrupt to calculate time. Then, from no of pulse in certain period of time, can calculate RPM.
robosang WROTE:show you ar? How to show you? Write the program for you? Or explain how to write program for you?
kenong WROTE:I have bought a rotary encoder kit, proudct RE08A, i want to know the wire connection given, is there have differentiate the wire which connect to 5V source, and which connect to signal?
Thxs.
robosang WROTE:kenong WROTE:I have bought a rotary encoder kit, proudct RE08A, i want to know the wire connection given, is there have differentiate the wire which connect to 5V source, and which connect to signal?
Thxs.
No User's Manual? Or Datasheet? Or Guide?
