tamiya motor 3 volt
tamiya motor 3 volt
Postby aswad » Fri Aug 02, 2013 11:03 pm
quite have problem with it, anyone can help?
can run but, not sync with my program
aswad
Re: tamiya motor 3 volt
Postby robosang » Sun Aug 04, 2013 8:37 am
What do you mean by Sync? How is it being controlled?
Postby aswad » Sun Aug 04, 2013 10:08 pm
using pwm,
if i misconnect the motor 2, motor 1 full speed as program.
aswad
Postby robosang » Mon Aug 05, 2013 9:18 am
Show us the hardware in detailed, what power source are you using? How is it being controlled from the controller?
Postby aswad » Thu Aug 08, 2013 1:35 am
here the circuit, any comment?
aswad
Postby robosang » Mon Aug 12, 2013 11:19 am
Not enough power from your battery, that is my guess.
Postby aswad » Thu Aug 15, 2013 3:04 am
so what battery must i use? can u suggest?
is it still not enough use 12 volt battery?
aswad
Postby yonghui » Thu Aug 15, 2013 10:44 am
12V from where? what kind of battery u are using.
can u try to control the speed of a single motor 1st? try to change speed from 0 to full speed.
Postby aswad » Thu Aug 15, 2013 11:17 am
one thing, my timer 2 pwm period is 51 micro second. is it suitable to 3 volt motor?
then is it correct to use timer 2 also in CCP2 PMW mode?
aswad
Postby yonghui » Thu Aug 15, 2013 3:12 pm
if u are using timer 2 in PWM mode, do not change the PR value since PR2 value will determine the period of the PWM. PWM frequency normally is in Kilo Hertz range. the higher frquency u have, u will get lower resolution of PWM. u try to read the datasheet of PIC. CCPR2 registers value will determine your duty cycle.
you can use the timer 2 interrupt as counter, but do not simply change the PR2 value.
