Cannot read usb arduino
Postby Hidayah » Thu Sep 26, 2013 7:26 am
hye.... i have a problem about my arduino usb port... why after i plug in usb cable for arduino, the usb cable cannot be register?
i have search at internet, and i follow the step but the usb cannot install successfully. i have download FTDI to com port. but not the solution. help please..
Hidayah
Re: Cannot read usb arduino
Postby robosang » Thu Sep 26, 2013 7:39 am
Which Arduino board you are using? Uno is not using FTDI anymore.
Postby Hidayah » Thu Sep 26, 2013 10:12 am
i'm using arduino uno r3 for my project...
Hidayah
Postby robosang » Thu Sep 26, 2013 5:55 pm
Are following the right instruction to install the driver? Doesn't seem to be right because UNO is not using FTDI anymore.
Postby ober » Sat Sep 28, 2013 12:28 pm
robosang is right, Uno is using another microcontroller as the USB to UART converter, please refer to :Getting Started with Arduino UNO for the detailed steps.
Postby Hidayah » Mon Sep 30, 2013 6:51 pm
i want to follow the instruction, but the hardware wizard like i attach not appear... how i need to install.
Hidayah
Postby ober » Mon Sep 30, 2013 10:00 pm
In that case, you might be using Win 7, try to follow the steps from Arduino: http://arduino.cc/en/Guide/windows
Postby Hidayah » Thu Oct 03, 2013 8:53 am
i follow half of the instruction but next instruction is
"Look under Ports (COM & LPT). You should see an open port named "Arduino UNO (COMxx)"
in my device manager not have port name arduino uno (com..)
how i need to do?
Hidayah
Postby robosang » Thu Oct 03, 2013 9:40 am
I think you better share the print screen of your Device manager.
It should have detect something when the Arduino UNO is plug into your computer using USB, even without correct driver.
Would be good too if you share photo of the Arduino connected to computer with USB cable.
Postby Hidayah » Thu Oct 03, 2013 9:58 pm
this is my device manager.. i plug in the usb for arduino but nothing happen (not have popup to install)
Hidayah
