CR038 with SK40C 16F877A.
Postby Julia » Fri Apr 25, 2014 2:01 am
hi..i try to rebuild the program of Mifare Reader CR038 with SK40C 16F877A given from the site without changing anything but the build failed.there are errors.. if i try to compile the file/source file one by one it successful build ...
the error is :
Error [1254] double.c; 55. could not find space (174 bytes) for data block
Error [1254] C:\Users\New folder\MifareReaderCR038withSK40C_16F877A\Mifare Reader CR038 with SK40C 16F877A\lcd.c; 362. could not find space (174 bytes) for data block
What's this error means?..
Julia
Re: CR038 with SK40C 16F877A.
Postby yonghui » Fri Apr 25, 2014 9:38 am
what is the compiler u are using? IDE used? and did u select the correct PIC device?
the error probably says that the Code size too large to fit into the selected PIC device
Postby Julia » Fri Apr 25, 2014 1:20 pm
i use mplab ide and HI-TECH C Compiler for PIC10/12/16..
but i try to rebuild another project example of PTK40A given and the rebuild success..
is there any ways to correct the error?
TQ
Julia
Postby ober » Fri Apr 25, 2014 9:19 pm
Please do printscreen the project window of MPLAB IDE and show us.
Return to RFID
