BlueBee bluetooth module questions
Postby peace4ever » Fri Nov 29, 2013 2:08 am
1) Can i change the default BlueBee name and password?
2) If i want to connect 2 android smartphone to BlueBee at the same time, is this possible?
peace4ever
Re: BlueBee bluetooth module questions
Postby gadgetng » Sat Nov 30, 2013 8:57 am
peace4ever WROTE:1) Can i change the default BlueBee name and password?
1. Since like you didn't study its User Manual. :twisted: Under User Manual page 13 and 14, there is AT command that can do it.
2. I don't think it is prossible.
gadgetng
Postby peace4ever » Sat Nov 30, 2013 12:35 pm
I am sorry the user manual instructions are a bit confuse to me, anyway thanks for your reply!
peace4ever
Postby dadieaxmal » Tue Sep 23, 2014 2:06 pm
Hi..
I already buy bluebee and skxbee...
The question is can i control bluebee via android?
How can i make it happen..
Thanks in advance....
dadieaxmal
Postby Idris » Tue Sep 23, 2014 5:37 pm
Hi dadieaxmal,
Of course you can connect Android bluetooth to Bluebee. There have many Android apps that available in play store that you can use for this purpose. For example you can try Arduino BT Joystick Free apps. What you need to know is the data received from that apps. So, to check it, try this step:
- Connect your Bluebee and Skxbee to your laptop/PC, make sure you know its COM port number.
- Open any telnet software (e.g. HyperTerminal or RealTerm) on your laptop/PC, select your Skxbee COM port.
- Open Arduino BT Joystick Free at your Android phone, connect to your Bluebee.
- Touch any button on the apps, you will see the data display on the telnet software each time you touch the button.
Those data is UART, so you can program your microcontroller to do any action based on that data.
If you want to sent data from Bluebee to your Android phone, you can try BlueTerm apps.
Postby ober » Thu Sep 25, 2014 9:03 am
Check out tutorial to connect BlueBee with Android phone by Idris:
http://tutorial.cytron.com.my/2014/09/24/connect-android-bluetooth-to-bluebee/
