Hi
Is there any tutorial for Lora point 2 point data transmission about Cytron Lora shield ?
Other case you don't want to change CS pin for sensor, you can change NSS of LoRa Shield by doing some hacking. You will have to bend the pin 10 leg of LoRa shield and connect it to any Arduino pin you like using a male-female jumper wire. Then change the pin configuration in the coding.
rf95.send((uint8_t*)(radiopacket.c_str()), radiopacket.length()+1);
