LoRa RFM shield long range configuration
Postby kelvinswee94 » Fri Dec 15, 2017 2:29 pm
hi i have two LoRa RFM shield so i make one as server and make one as client. is there any configuration needed in order for me to transmit the data in long range?
i have test my LoRA RFM shields but they can only transmit up to 50 meters only. More than 50 meters LoRa RFM shields are unable to communicate with each other.
please advise thanks
kelvinswee94
Re: LoRa RFM shield long range configuration
Postby bengchet » Fri Dec 15, 2017 4:16 pm
LoRa range can be affected by the environment and the installation of antenna. Environment should be open air and no obstacles in line of sight for 2 device to maximize the communication range. As for antenna, you will need to find higher grade antenna for longer range, for example here
Hope it helps, thanks.
Postby Sukuri » Mon Feb 05, 2018 8:39 am
I've bought LoRa RFM95 here: https://www.cytron.io/p-shield-lora-rfm
can I know the bandwidth of the antenna please?
Sukuri
Postby bengchet » Tue Feb 06, 2018 9:48 am
Current antenna supports 900 - 923MHz, center frequency will be 915MHz.
