using lsa08 with arduino
Postby safvan » Wed May 15, 2013 4:42 pm
hello,
i wanted to use cytron lsa08 line sensor on my arduino using uart. could anyone tell me how to do it?
safvan
Re: using lsa08 with arduino
Postby waiweng83 » Thu May 16, 2013 9:24 am
Have you read through the user's manual?
waiweng83
Postby Le0pa_RD » Mon Dec 11, 2017 3:03 am
I tried lsa08 with serial UART communication
It works with digital output (UART mode 1) but it doesent with (UART mode 3)
anyone can help?
Thanks
Le0pa_RD
Postby ober » Mon Dec 11, 2017 4:47 pm
If it works on UART mode 1, the LSA08 is working, I think you need to check your code. How your code handle the payload?
Postby Le0pa_RD » Tue Dec 12, 2017 12:21 am
Can you post a working code please?
I checked my code but i don't understand what's wrong
Le0pa_RD
Postby Idris » Tue Dec 12, 2017 6:08 pm
Hi Le0pa_RD,
Could you share a few clear photos/videos of your hardware setup? Including the code that you write to Arduino.
Currently I don't have a sample code for LSA08.
Postby Le0pa_RD » Wed Dec 13, 2017 10:47 pm
This is my code.
Nothing wrong with the hardware.
UART mode 2 works as well it's just mode 3
can anyone help?
const byte rx = 0;
const byte tx = 1;
const byte serialEn = 6;
int data[9];
void setup() {
  pinMode(serialEn,OUTPUT);
  digitalWrite(serialEn,HIGH);
void loop() {
  byte dummy = 0;
  for(int i=0; i<9; i++){
    digitalWrite(serialEn,LOW);
      while(Serial.available() <= 0);
    dummy = Serial.read();
    data[i] = dummy;
  if(data[0] != 0)
    Serial.println("Array not valid");
  else{
    Serial.print("Array: ");
    for(int i=1; i<9; i++){
      Serial.print(data[i]);
    Serial.println();
Le0pa_RD
Postby Le0pa_RD » Sun Dec 24, 2017 3:30 am
I tried with software serial too...
No results
Anyone?
Le0pa_RD
Postby ober » Tue Dec 26, 2017 8:59 am
Le0pa_RD WROTE:This is my code.
can anyone help?
const byte rx = 0;
const byte tx = 1;
int data[9];
void setup() {
void loop() {
  byte dummy = 0;
    data[i] = dummy;
  if(data[0] != 0)
  else{
    Serial.println();
How you do configure the LSA08 into mode 3?
Postby Le0pa_RD » Fri Dec 29, 2017 2:15 am
In the UARTMODE menu on the sensor...
Le0pa_RD
