MDDS30 simple serial
Postby Arska » Tue Jan 22, 2019 5:24 am
I am driving the mdds30 using usb2rs232 converter from ubuntu, Qt and c++. I tested simple serial mode with one motor. Motor is rotating ok using the test button. But from the software it seems that operation is not following the protocol. What I found was that bit 0 is controlling rotation direction. And speed bits order is reversed. I didn't yet tested the channel bit.
7 6 ... 1 0
ch speed lsb ... speed msb dir
Is my finding correct or am I missing something obvious.
I also tried the packetized mode quickly, but with no success. It seem to be waiting autobauding, even after I send 0x80 byte to it. I suppose that calculating the checksum is as simple as manual say; byte3 = byte0 + byte1 + byte2. Needs more testing.
Any suggestions and thanks in advance
Arska
Re: MDDS30 simple serial
Postby Arska » Tue Jan 22, 2019 10:13 pm
I figured the obvious thing that I missed. RS232 voltage levels are not correct, because drive use TTL-level signals. I purchased USB->TTL converter cable and now the system works as it should.
Arska
Postby Idris » Thu Jan 24, 2019 9:28 am
Hi Arska,
Great findings. Yes, microcontroller signal level is based on TTL. Anyway, your project looks interesting, do you mind to share a clear video on how do you operate the driver?
