miss green WROTE:it have a sensor to indicate the wter and food lvel when it is minimum..it has voice record to call the pets and the user can set the timer for how many hours..
miss green WROTE:as for the food lvel min i thought of using sensor so when the lvel is mnimun the buzzer or LED will light..how about to cntrl the flow of food especially the water?
ABSF WROTE:miss green WROTE:as for the food lvel min i thought of using sensor so when the lvel is mnimun the buzzer or LED will light..how about to cntrl the flow of food especially the water?
Is this project for your FYP? If not, for water feeding, there is a special designed bottle placed up-side-down. At the mouth of the bottle there is a mechanism. When dog or cat is drinking water from it, the pet's mouth would pressed against the lever to release the water. When the lever is not pressed, the water will stop.
For automation, you can visit a fish aquarium, and see if they have any small water pumps operating at low DC voltages. OR you can use the electric valve of a washing machine that can on and off the water from the water tap.
For food feeding, you have to visit the pet shop looking for food that can last 7 days in case you're away and nobody was there to feed your cat. Meat or fish will get rotton and becomes not fresh. You have to use more of your imagination.
