GSM not responding to pic
Postby wan88 » Sat Mar 03, 2012 1:20 pm
I'm working on the GSM+pic project on both http://tutorial.cytron.com.my/2011/12/08/control-and-monitor-via-sms/ and http://shahrulnizam.com/pic-lesson-gsm-modem/. Unfortunately I didnt receive any response from the GSM. Im using iTegno 3832 modem. I've check the GSM with HT and its working fine. Can anyone help me with a solution
wan88
Re: GSM not responding to pic
Postby shahrul » Sat Mar 03, 2012 10:23 pm
Post your schematic and hardware photo.
Postby wan88 » Sun Mar 04, 2012 10:09 am
I'm using the schematic and coding provided by the projects. This is the pic of my hardware for your blog project Image
wan88
Postby wan88 » Tue Mar 06, 2012 11:01 am
I've measure the voltage across pin 13 for max232 and i get -7V. I also notice that there is no voltage across pin 14 max232. Are this suppose to happened?
wan88
Postby shahrul » Tue Mar 06, 2012 11:24 am
wan88 WROTE:I've measure the voltage across pin 13 for max232 and i get -7V. I also notice that there is no voltage across pin 14 max232. Are this suppose to happened?
Pin 14 is transmit, should have voltage. Look your picture, I'm not sure what capacitor value you use. It should be electrolitic capacitor (not ceramic) with value 10uF.
Postby wan88 » Tue Mar 06, 2012 11:36 am
TQ for the reply. I've been figuring this out for ages now. I will try and change the capacitor
wan88
Postby wan88 » Tue Mar 06, 2012 12:29 pm
I've change the capacitor and still it give the same voltage and no GSM response. :(
wan88
Postby shahrul » Tue Mar 06, 2012 12:39 pm
wan88 WROTE:I've change the capacitor and still it give the same voltage and no GSM response. :(
The best thing, you see the waveform with oscilloscope. Check pin 11, 14, 13, 12 of MAX232. This is step beginner should do.
Postby robosang » Mon Mar 12, 2012 8:19 pm
Er... why don you test your MAX232 circuit with a computer COM Port. Since the microcontroller should send some text to Modem. So now use the computer as modem, bare in mind you will need to cross the Tx and Rx line if you are sending it to computer, and later when you are done with computer, swap back the Tx and Rx.
Postby wan88 » Mon Mar 12, 2012 9:28 pm
robosang WROTE:Er... why don you test your MAX232 circuit with a computer COM Port. Since the microcontroller should send some text to Modem. So now use the computer as modem, bare in mind you will need to cross the Tx and Rx line if you are sending it to computer, and later when you are done with computer, swap back the Tx and Rx.
can u guide me how to do that? or maybe a link to help me?
wan88
