wan88 WROTE:I've measure the voltage across pin 13 for max232 and i get -7V. I also notice that there is no voltage across pin 14 max232. Are this suppose to happened?
wan88 WROTE:I've change the capacitor and still it give the same voltage and no GSM response.
robosang WROTE:Er... why don you test your MAX232 circuit with a computer COM Port. Since the microcontroller should send some text to Modem. So now use the computer as modem, bare in mind you will need to cross the Tx and Rx line if you are sending it to computer, and later when you are done with computer, swap back the Tx and Rx.
